dogvomit
Oct 02, 2026Aspirant
RS700 is sending BPDU packets only when in AP mode
I have an issue with RS700 where it sends BPDU packets and causes the switch port to put ports into err-disable state, but only when it is set to AP mode. Switch is required to have BPDU Guard enable...
dogvomit
I am experiencing a similar issue.
I have an issue with RS700 where it sends BPDU packets and causes the switch port to put ports into err-disable state, but only when it is set to AP mode. Switch is required to have BPDU Guard enabled.
The RS700 has firmware 1.0.11.8, which is the latest shown on Netgear support page.
I opened a support ticket for this issue but did not receive a resolution.
