dogvomit
Oct 02, 2026Aspirant
RS700 is sending BPDU packets only when in AP mode
I have an issue with RS700 where it sends BPDU packets and causes the switch port to put ports into err-disable state, but only when it is set to AP mode. Switch is required to have BPDU Guard enable...
dogvomit
Oct 09, 2026Aspirant
I encountered an issue involving the Netgear RS300 operating in Access Point (AP) mode. I am also opening a support ticket for this behavior but thought I would post here in case anyone else has experienced a similar issue.
Problem Description
When an RS300 running firmware 1.2.7.2 is connected to a Cisco switch port configured with BPDU Guard, the Cisco port immediately transitions to an err-disabled state.
Cisco switch log:
%SPANTREE-2-BLOCK_BPDUGUARD:Received BPDU on port Gi6/46 with BPDU Guard enabled. Disabling port. %PM-4-ERR_DISABLE:bpduguard error detected on Gi6/46, putting Gi6/46 in err-disable state
Wireshark Analysis
To isolate the problem, I disconnected the Cisco switch and connected only:
RS300 (AP Mode) | +--- Windows Laptop running Wireshark
No other networking devices were connected.
The RS300 LAN MAC address is:
28:94:01:0e:04:78
Using Wireshark with the filter:
stp
I observed the RS300 transmitting STP Configuration BPDUs approximately every two seconds.
Observed BPDU details:
Destination MAC: 01:80:C2:00:00:00
Protocol: Spanning Tree Protocol (STP)
BPDU Type: Configuration
Root Identifier:28672 / 0 / 28:94:01:0e:04:78
Bridge Identifier:28672 / 0 / 28:94:01:0e:04:78
The Root Identifier and Bridge Identifier match the RS300 LAN MAC address, indicating that the RS300 is originating the STP BPDUs and acting as the root bridge.
Firmware Comparison
I currently have two RS300 units available:
RS300 #1
Firmware:
1.0.1.90
Behavior:
AP Mode enabled - No STP/BPDU packets observed in Wireshark. Does not trigger Cisco BPDU Guard
RS300 #2
Firmware:
1.2.7.2
Behavior:
AP Mode enabled - Transmits STP Configuration BPDUs. Triggers Cisco BPDU Guard
This suggests a behavioral change or regression between firmware versions.
Downgrade Attempt
I attempted to downgrade the RS300 running firmware 1.2.7.2 to firmware 1.0.1.90.
The downgrade was rejected by the device and did not complete successfully.
