Jeff12341
Aug 27, 2025Aspirant
RS700 Issues
After updating my Nighthawk RS700 router’s firmware to V1.0.9.6, several devices stopped connecting, and the device name database became corrupted where device names got assigned to other devices ran...
Jkov87
Oct 12, 2025Aspirant
Hello BH_C and RichardTTT - I also have the RS700 running on the latest available v1.0.9.6 Firmware, and am encountering the same device database issues after spending the time to painstakingly set-up my "Attached Devices" Access Control table, with the Device Name / Assigned IP Address / MAC Address detailed mappings, which randomly change on their own.
Could you please send me the Beta/Trial Firmware to try/test? I would really appreciate it! Thank you in advance.
Feature Request:
I really wish the UI contained an "Export" / "Import" function for this "Attached Devices" table and/or the LAN Setup IP Address Reservation Table - using something like a CSV formatted text file - since this is a very tedious process to set-up and modify within the UI one-by-one and would be much easier to manage via CSV, as the "Backup Settings" file is not viewable or modifiable and can have compatibility issues between firmware updates. This is especially frustrating when problems occur and thus requires manual set-up of all of my router device mappings from scratch all over again, individually one-by-one via UI buttons, when restoring the backup file doesn't work or updates need to be made.
RichardTTT
Oct 13, 2025NETGEAR Expert
Hi,
I just sent you a direct message. Please check your inbox.
