stoves
Sep 27, 2025Follower
RS700 issues
okay - I am no expert when it comes to networking but I’m also not a complete newbie. I have never had issues likely current rs700 related ones. Setup info: access control is on i have separat...
CrimpOn
Sep 27, 2025Guru - Experienced User
stoves wrote:the r9000 has an up assigned
Typo? i.e. "up" instead of "ip"?
Typically, the web management interface on Netgear routers can be accessed only from a device connected to the "LAN side" of the router. (either one of the Ethernet LAN ports or the WiFi network broadcast by the router. Since this R9000 has the WiFi disabled, the only access will be from a device connected to an Ethernet port on the R9000.)
How were you attempting to connect to the R9000?
