omar1986's avatar
omar1986
RS700 keeps forwarding me to the routerlogin.net/genie_index.htm even after its been set up
This AP keeps redirecting me the the routerlogin setup page even though its been fully set up and functional. Im trying to access the management page on my connected android phone. I'm aware there's an app I can use that might work, but I really would rather use the browser.
  • FURRYe38's avatar
    Does this happen with a wired or wireless PC or laptop?
    What browser are you using on the mobile phone?
    Try 192.168.1.1 in the browser?
    • omar1986's avatar
      omar1986
      BTW on a wired computer on LAN i still get routed to the same page and on top of that the page does not display and instead i get
      404 - File or directory not found.
      • FURRYe38's avatar
        Sounds like something is messed up on the WEB Ui.
        Might do a factory reset and walk thru the setup wizard with the wired PC and web browser. Be sure to write down important information for safe keeping. Use MS Edge browser.
  • BH_C's avatar
    BH_C
    NETGEAR Expert
    What is the URL you specified to access the Web GUI?
