lok518
Nov 27, 2025Tutor
RS700 randomly lose Internet connection
I’ve been using the RS700 router for about two weeks. Everything was fine at the beginning, but recently it started to randomly lose Internet connection. Here’s what happens: The Internet sudden...
- Dec 10, 2025
For similar issues would be solved with trial fw
Nov 27, 2025Guru - Experienced User
Using ISP Detected DNS or custom DNS?
Is IPv6 and Protection Engine enabled on the RS router?
lok518
Nov 27, 2025Tutor
Huawei OptiXstar HN8250Ts-20.
Tried ISP Detected DNS and custom DNS, currently using 8.8.8.8 and 8.8.4.4.
IPv6 is disabled but not seeing protection engine on the portal, seems protection engine is part of NETGEAR Armor? I have just disabled it.
