lok518
Nov 27, 2025Tutor
RS700 randomly lose Internet connection
I’ve been using the RS700 router for about two weeks. Everything was fine at the beginning, but recently it started to randomly lose Internet connection. Here’s what happens: The Internet sudden...
- Dec 10, 2025
For similar issues would be solved with trial fw
lok518
Dec 10, 2025Tutor
- FURRYe38Dec 10, 2025Guru - Experienced User
Did you get some trial FW?
- lok518Dec 13, 2025Tutor
yes
- FURRYe38Dec 13, 2025Guru - Experienced User
Glad the trial FW got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
