MrChrisH
Oct 23, 2025Aspirant
RS700 VPN Service certs incomplete?
I've been setting up NoIP and the VPN Service on my RS700. I'm on firmware version V1.0.9.6_2.0.100. After much tinkering and following much of the helpful advice here, I have a connection that ...
CrimpOn
Dec 30, 2025Guru - Experienced User
If you learn something useful and are allowed to 'share', please update the conversation.
I notice the same WARNING about certificate verification method when using OpenVPN with my ancient Orbi system. (Opened a VPN connection just now)
I wonder if this could be a situation similar to the frustration we all experience with modern web browsers issuing similar warnings about the web interface of the router itself. i.e.
- If we connect using http, browsers warn UNSAFE, because by definition http is not encrypted and thus "unsafe".
- If we connect using https, browsers warn UNSAFE, because the SSL certificate is self-signed and thus there is no "God Like" certificate authority guaranteeing that this SSL certificate belongs to the organization claiming it.
These warnings, of course, overlook the plain fact that WE deliberately CHOSE which web site for the connection (our own router, on our network). We did not get a link from some site on the internet or from a suspect email.
In a sense, our use of OpenVPN is similar. WE chose to open a connection to this specific IP address (or DDNS address) and we are exchanging Keys that WE created using OpenVPN on our router.
For YEARS, I have simply ignored that OpenVPN warning when using OpenVPN. If there is a simple method to (a) make the warning disappear and (b) improve security, I'm all for it.
- MrChrisHJan 03, 2026Aspirant
CrimpOn thanks for your message.
Yes, you might well be correct and I could have been over thinking this! When seeing warnings re security I do like to triple check what they are indicating.
I have since found a different approach for my needs and decided to not use Open VPN. Part of that was due to me not fully understanding the possible risk I was being warned about by Open VPN.Additionally, for my RS700 router, Netgear have released a new version of the firmware (V1.0.10.8 - from here https://www.netgear.com/support/product/rs700s ) which may (I have not tested) contain a fix that addresses this.
