MrChrisH
Oct 23, 2025Aspirant
RS700 VPN Service certs incomplete?
I've been setting up NoIP and the VPN Service on my RS700. I'm on firmware version V1.0.9.6_2.0.100. After much tinkering and following much of the helpful advice here, I have a connection that ...
CrimpOn
Jan 03, 2026Guru - Experienced User
Thanks for the update. If by chance you test OpenVPN on the new firmware, it would be helpful to hear the results.
There are other methods to provide remote access to the LAN, such as installing Wireguard on a local computer or purchasing a device that supports OpenVPN/Wireguard.
I have not investigated whether other methods trigger warnings similar to this one.
