Intoxicating
Jul 03, 2025Star
RS700 WAN lease issue
Hello, I've got an issue where by the WAN lease doesn't get renewed before expiry which then causes the Internet to be disconnected until restarting the RS700 (app & web login becomes unresponsiv...
Jul 03, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- IntoxicatingJul 03, 2025Star
The ONT is an ADTRAN 622V, cable is CAT6A STP.
Thanks,
Tim
