PJsouza
May 14, 2025Aspirant
RS700 WIFI coverage issues - extender?
Hello Everyone, I have a 2500 sq. ft. single story home I am having WIFI coverage issues with my RS700. Netgear support is suggesting an extender. Below are the options offered. https://www.n...
May 14, 2025Guru - Experienced User
A few more details might be needed before jumping right to an extender.
- what are the interior walls made from?
- what speeds do you want to achieve? (aka what are you using it for? )
- What actual issue are you having? I never trust tier 1 support from netgear. A better description of your actual issue would help.
PJsouza
- I have standard dry walls. Nothing fancy
- best WIFI signal and performance possible.
- My laptops (HP & Acer laptops Windows & Mac Pro M4) and my iPads are experiencing low signal strength and low performance.
My router is mounted on a shelf near the ceiling. Garage, Family, living, and dinning rooms signal and performance just ok.
Thanks for any input.
