PJsouza
May 14, 2025Aspirant
RS700 WIFI coverage issues - extender?
Hello Everyone, I have a 2500 sq. ft. single story home I am having WIFI coverage issues with my RS700. Netgear support is suggesting an extender. Below are the options offered. https://www.n...
May 19, 2025Guru - Experienced User
2500 ft all on one level is a pretty sizeable home. The router might be able to cover it decently if its centrally located.
Is the router centrally located or at one end of the home?
And does the extra coverage need the "Wifi 7" speeds?
Or will it be fine with an extender like the EAX80 or EAX17 (eax17 is pretty solid, I have one and the eax80)
