michaeljeger
Jun 18, 2026Guide
RS700S — Wi-Fi upload capped at ~400 Mbps in router mode only (hardware acceleration / ONT issue)
Here's the summary for the online support form in English, with the current ~400 Mbps figure: Subject: RS700S — Wi-Fi upload capped at ~400 Mbps in router mode only (hardware acceleration / ONT issu...
Jun 18, 2026Guru - Experienced User
What wireless brand and model # are you connecting to the router?
How is the wirelss configured on the RS?
Smart Connect enabled or disabled? Try disabled?
What channels are you using?
Be sure that your wireless device is connecting to the 5 or 6Ghz radios for speed testing
Make contact with NG support for RMA needs.
schumaku
FURRYe38 wrote:What wireless brand and model # are you connecting to the router?
Not many variants available:
michaeljeger wrote:multiple clients (iPhone and MacBook),
FURRYe38 wrote:Smart Connect enabled or disabled? Try disabled?
There must be an awful mass of concurrently active 5 and 6 GHz traffic on air to cause such issues constantly.
