Raiden85
Jan 12, 2026Star
RS700S Firmware Version 1.0.10.8 IoT Option Missing
So looking at the change logs for the RS700 you added a new feature, Added an IoT network function in the web user interface." But no matter where I look, I cannot find this option anywhere. I...
- Jan 14, 2026
IoT is under Advanced > Advanced Setup > Wireless Settings. Then you’ll see a tab for IoT Network.
GrinningSharky
Jan 15, 2026Tutor
Sadly, based on my preliminary testing, the IoT function is kind of worthless. It doesn't appear to create a dedicated network for IoT devices that CANNOT access my main network. It assigns IP addresses from the main network and after testing it from a computer, I can completely access all my network resources from it. Isn't the point to be isolated from the main network much like the guest network can be?
coolwifi
Jan 16, 2026Virtuoso
Is the IoT network 2.4 Ghz only or dual band? Isolation would remove the access of IoT devices from the main network, which would be unintuitive.
