Raiden85
Jan 12, 2026Star
RS700S Firmware Version 1.0.10.8 IoT Option Missing
So looking at the change logs for the RS700 you added a new feature, Added an IoT network function in the web user interface." But no matter where I look, I cannot find this option anywhere. I...
- Jan 14, 2026
IoT is under Advanced > Advanced Setup > Wireless Settings. Then you’ll see a tab for IoT Network.
CrimpOn
Jan 16, 2026Guru - Experienced User
On every other product, the IoT network supports 2.4G and 5G and the user can enable/disable them independently.
