superuser2510
Apr 21, 2026Aspirant
RS700s reducing speed to 90mbps.
So I have the BGW320 in IP passthrough mode and connected the blue 5GB port from the BGW320 to the WAN port on my RS700s. Intially I had connected the two with a 6ft cat5e cable and was getting a dow...
superuser2510
Its the same thing. I've tried from BGW gig port to RS WAN and still getting 90. Im very tempted to see if I move the RS back in the same room as the BGW and use a 6ft CAT6 cable and see if I get faster speeds. If that is the case I'll move the BGW to be next to the RS so that I can use the 6ft cable.
Apr 21, 2026Guru - Experienced User
Let us know.
