olegeezer's avatar
Jan 30, 2025
RS700S V1.0,7,96_2.0.96 slows speed
Hello again. I downloaded RS700S V1.0.7.96_2.0.96ck and as a result, my download and upload speeds slowed down. It continued even after I updated all drivers on my OS and reset my RS700S to factory specifications.
I had to roll back my RS700S firmware to 1.0.7.86 firmware before my download and upload speeds returned tp 1.25Gig speed.
Seems there is a problem with the latest V1.0,7,96 firmware.
Thanks, Matt
  • Hello to all.
    I spoke with netgear yesterday, 01/28/2025 on how to update the download and upload speeds in netgear RS700S. Netgear had no answer.
    Well, I figured out why. To update download and upload speeds, you sign in to 192.168.1.1.
    Then select QoS. To update the download and upload speeds, you must first turn on QoS. Then run speedtest,
    then Apply. Now you can turn off QoS if you want. I should have done that before calling Netgear.
     Thanks, Matt
    • FURRYe38's avatar
      So this fixed the speed issues then?
      • olegeezer's avatar
        olegeezer
        Guide
        I had to enable QoS before I could update download and upload speeds in 192.168.1.1.
        I had to roll back the new firmware V1.0.7.96 because it was slowing my internet speed.
