klarue13's avatar
klarue13
RS90-Can't connect to a Chromecast/Google Streamer?
Picked up the RS90 earlier today and got everything set up pretty easily. Only issue is that the Chromecast and Google Streamer won't seem to connect.
I managed to get the Chromecast connected earlier, but it didn't last all that long and eventually disconnected. Is there a setting I've screwed up somewhere? Or is Google just not compatible with Wifi 7 or something?
I believe I'm on the latest firmware (v1.1.1.94), and everything else seems to be running fine, so any suggestions are super appreciated. Thanks!
  • WiFi7 is "backward compatible" with both WiFi6 and WiFi5.  These devices should connect...... unless.... the router has been set to a security level that the Chromecast does not support.  (WPA3?)
    This seems unlikely since the Chromecast has connected successfully... correct?
    Yes, 1.1.1.94 is the most recent firmware for the RS90.
  • Thanks for bringing up the security settings; that seems to have done the trick. It was set to WPA2+WPA3 by default, so I have no idea why the chromecast was able to connect briefly before.
    Looks like I'm good though now; thanks!
  • If your RS90 can't connect to a Chromecast or Google streamer, try the following:
    Check Wi-Fi: Ensure both devices are on the same network.
    Restart devices: Power cycle the RS90 and Chromecast.
    Update firmware: Ensure the RS90 and Chromecast have the latest updates.
    Enable casting: On the RS90, confirm casting/streaming settings are enabled.
    Reset network settings if all else fails.
  • CrimpOn's avatar
    CrimpOn
