Webscout5091
Jul 08, 2025Follower
RS90 Ethernet Ports Don’t Work
I purchased the RS90 WiFi 7 router 2 weeks ago. It performed flawlessly for the first day. The WiFi is top notch. The problem I am now dealing with is that none of the Ethernet ports work on the bac...
BH_C
Jul 09, 2025NETGEAR Expert
When the switch is connected to a port on RS90, is the LAN LED (the 3rd one from the top, the top is power LED) turned on?
Direct connection from a device to the RS90 (if you have a cable long enough) is a good way to troubleshoot the issue, please let us know how it does if you can do it. Thanks.
By the wsay, you can PM me your support case number and I will look into it.
