jomeek02
Mar 13, 2026Aspirant
Setting RS600 Router
Recently purchased a RS600 router. Followed the instructions that came in the box with the router. And still unable to get the internet. I connected the computer to the modem and could get the int...
CrimpOn
Mar 13, 2026Guru - Experienced User
Thank for for responding so quickly. Are you able to connect to the RS600 using a computer (page 22). There should be a menu item for Internet Setup.
Since a computer connected directly to the modem got an internet connection, it would seem that the Internet Service Provider (ISP) does not require a login (user name/password).
