bcas400g64's avatar
bcas400g64
Slow PS5 downloads wired connect RS200
Hello,
Just got the RS200 Nighthawk and while my wireless  speeds for phones/and other devices is great, it's 1/2 the download speed I had on older router. I was getting over 500mbps and now just over 225.  I am stumped.
Any help is appreciated.
  • It seems if you disable armor on router app it solves the problem.
    Question is why is it only affecting the PS5??
  • FURRYe38's avatar
    Try enabling Armor then disable Protection Engine on the RS.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      You might want to try to whitelist the PS5 in Armor
      How to create a Netgear Armor device exception:
      1. Open the app: Launch the Netgear Nighthawk or Orbi app on a device connected to your network.
      1. Navigate to Security: Go to the "Security" section of the app.
      1. Access device management: Find the option to manage connected devices.
      1. Select the device: Choose the specific device you want to allow access to.
      1. Set exception: Mark the device as "allowed" or "trusted" to create the exception.
