trbeat
Nov 10, 2024Follower
Slow Upload Speeds…
After going through SSID issues, I have a working RS500 with amazing download speeds - BUT…. Upload speeds of 5 to 6 Mbps.
My RS500 is connected directly to the ONT, a Verizon FIOS Alcatel I-211M-L.
I saw some say the resolution for them was to upgrade the ONT to a 2GB service - which I am actually happy to do as it will benefit what I do at work - but I’d like to get a feel for is this a solution or is the RS500 just going to be a pain and I need to consider a different router?
Anyone else running a RS500 and FIOS with good upload speed?
Thank you everyone.
Be sure your using a good quality LAN cable between the modem/ONT and router. CAT6A STP is recommended.Check the Connection rates seen between the RS and ONT and with a wired PC connected on the RS web page under Advanced tab/Show Stats.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed? A complete pull of the power adapters from the ONT and RS for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interfaceSpeed test with a wire connected PC to the back of the RS router using Ooklas installable speed test app.
Also test with a 2nd PC for comparison.
if you direct connect that same pc to the ONT, what speeds do you get?
- BH_CNETGEAR Expert
Regarding the slow upload speed issue, especially when the RS router is connected to an ONT, we have a trial firmware build that may resolve the issue. It worked in our test.
If you would like to give it a try, please let me know your RS router model and I will PM you the firmware.
Thanks.
