jaimea
Jun 22, 2026Aspirant
Starlink Router
I bought a Netgear Nighthawk RS300 to be used with Starlink. I viewed a video that showed that you may not use the Starlink router and connect your own router directly to the Starlink power base and...
Jun 22, 2026Guru - Experienced User
Something to check with the ISP about or check online guides regarding the Starlink routers removal and configuration of another router.
There maybe special configurations needed by the ISP to be set on the RS router to help make it work.
Other options:
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
