TheSaint1
Dec 03, 2025Tutor
The first time I had the issue I think I had seen there was an update the day prior to the V1.0.9.16
I am having issues with Firmware Version V1.0.9.16 It was a recent update just before thanksgiving I believe. Since then my router has dropped internet and stayed disconnected. I have...
TheSaint1
Dec 03, 2025Tutor
To clarify. My internet will disconnect once a day and stay disconnected until turn it off and let it turn back on. Then it will work normal until the next day. I’m on Truvista 2GB fiber internet in Chester SC.
400feetup
Dec 03, 2025Guide
try unplugging and plugging back in the ethernet cable from the ONT. Alternatively, you can go into the router GUI and do a release/renew for the router to grab DHCP. Make sure you get the original firmware version and do a backup copy of the router before you do any possible updates. FURRY is a great resource here, also Netgear staff as well should be able to reach out and assist if need be.
