TheSaint1
Dec 03, 2025Tutor
The first time I had the issue I think I had seen there was an update the day prior to the V1.0.9.16
I am having issues with Firmware Version V1.0.9.16 It was a recent update just before thanksgiving I believe. Since then my router has dropped internet and stayed disconnected. I have...
Dec 03, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 and Protection Engine enabled on the RS router?
TheSaint1
Dec 08, 2025Tutor
Hey, FURRY!
I reverted it back to V1.0.7.96. Make Adtran, model# SDX622xv, ISP - TruVista Fiber, 2GB Fiber plan. Yes Cat 6A. No to IPv^ we are still using IPv4. No a factory reset was not completed as I have all my devices perfectly labeled in the system.
