smoothster
Jul 22, 2025Star
Unable to upgrade FW stuck on firmware v1.0.7.86
RS700 stuck on firmware v1.0.7.86_2.0.82 My RS700 shows a firmware update available, but the update process goes through and ends up with the original version. I have even tried a factory reset ...
Jul 23, 2025Guru - Experienced User
did you try using tftp or nmrpflash?
smoothster
Jul 23, 2025Star
tried tftp, but don't think I ever successfully got the RS700 into tftp mode
- RichardTTTJul 23, 2025NETGEAR Expert
Hi,
I just PM you a message, can you check it?
Thanks,
Richard.
