MagnumForceGB
Jun 15, 2025Aspirant
"Up to 5.8 Gbps" it only uses 20 Mhz
I am having the same issue, it keeps going to 20 MHz even though I'm trying to use this for a Quest 3 wireless access point. 20 MHz is not cutting it either for steamVR. I bought this router exclus...
MagnumForceGB
If I set the mode to "Up to 2.9 Gbps" it uses 160 MHz, but "Up to 5.8 Gbps" it only uses 20 Mhz
