MagnumForceGB
Jun 15, 2025Aspirant
"Up to 5.8 Gbps" it only uses 20 Mhz
I am having the same issue, it keeps going to 20 MHz even though I'm trying to use this for a Quest 3 wireless access point. 20 MHz is not cutting it either for steamVR. I bought this router exclus...
Router2371
Dec 02, 2025Aspirant
I confirm the same issue. So for my new rs500, I cannot get 320. Best I can do for 6g is to set it to 'up to 2.9gbps' and it will get to 160. No other combo of channels/speeds works to get 320. My ASUS router has no problem doing 320 for 6ghz. How can I get this rs500 to work at 320?
- William3087Dec 03, 2025Aspirant
if you find any solution let me know
- StephenBDec 03, 2025Guru - Experienced User
MagnumForceGB wrote:
I have another 6 GHz router that uses channel 5 and it can get access to the full 320 MHz, but this one won't even though the box says it can do 320 MHz in 6 GHz band.
If you try channel 5 on the RS300, are you getting different behavior?
- WarmHelp_NTGRDec 03, 2025NETGEAR Expert
Hi Router2371
Thank you for the additional details. To better understand the behavior you're seeing on the RS500, could you please let us know which 6 GHz channel the router is currently using when you're testing the “Up to 2.9Gbps” and “Up to 5.8Gbps” modes?
If the channel is set manually, please let us know the channel.
