MagnumForceGB
Jun 15, 2025Aspirant
"Up to 5.8 Gbps" it only uses 20 Mhz
I am having the same issue, it keeps going to 20 MHz even though I'm trying to use this for a Quest 3 wireless access point. 20 MHz is not cutting it either for steamVR. I bought this router exclus...
Router2371
Dec 02, 2025Aspirant
I confirm the same issue. So for my new rs500, I cannot get 320. Best I can do for 6g is to set it to 'up to 2.9gbps' and it will get to 160. No other combo of channels/speeds works to get 320. My ASUS router has no problem doing 320 for 6ghz. How can I get this rs500 to work at 320?
Dec 03, 2025Guru - Experienced User
MagnumForceGB wrote:I have another 6 GHz router that uses channel 5 and it can get access to the full 320 MHz, but this one won't even though the box says it can do 320 MHz in 6 GHz band.
If you try channel 5 on the RS300, are you getting different behavior?
