tbn6
Nov 19, 2025Aspirant
When I have all devices dropping off the internet this is a major problem
I am experiencing the same issue for the past few weeks. This is a router/firmware issue that Netgear needs to resolved urgently. When I have all devices dropping off the internet this is a major pro...
Nov 19, 2025Guru - Experienced User
What devices are dropping off the internet? Wireless and wired devices?
What router model is this?
What FW version is loaded on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Is IPv6 or Protection Engine enabled on the router?
