Redbarn1927's avatar
Redbarn1927
Follower
Jul 27, 2025
Wifi range - RS200
Hello,
I keep finding things that say I can adjust my WiFi Range, however there is nothing in the router settings page when I log into it from my browser and go to "wireless". It is on the latest firmware. It was also just installed tonight. Works alright otherwise I just don't want or need the WiFi signal reachable from the road. Thanks
1 Reply
  • CrimpOn's avatar
    CrimpOn
    On some Netgear WiFi routers, there is an Advanced Setting which allows the user to change the Transmit Power.  This is part of a menu option in the web interface (not the 'app').
    Alas, these "advanced settings" are not described in the User Manual.  The RS200 User Manual contains no mention of such a setting.
    My guess is that it does not exist on this product.
    (but, I do not have one and cannot look through the web interface)
    Providing a link to this information would be a big help.
