Hoodcanalguy
Oct 07, 2025Aspirant
wifi7 connection problems with iphone 17
i have a rs700s i just got the iphone 17 pro max its supposed to connect wifi7 but wont i have a galaxys25 ultra that connects no problem ive worked with apple tech support and they suggested a...
- Oct 07, 2025
(Caveat: I have no personal experience with WiFi7.) However, it appears that using WiFi7 requires WPA3.
This might put the user in an awkward situation:
- Many devices are not capable of WPA3 and will be left unable to connect if the security level is WPA3 only.
- Perhaps the Samsung phone can distinguish that these security settings are "ok" and the iPhone balks at the combination.
It might be an interesting experiment to temporarily change the WiFi security setting to WPA3 and "see what happens"
- If the iPhone still refuses to connect as WiFi7, well that was a dumb suggestion. sorry.
- If the iPhone will connect with WiFi7, but other devices have problems..... (oh dear).
Might be an interesting 10 minutes.
Oct 08, 2025Guru - Experienced User
Can you provide a screen capture of the top portion of the Galaxy 25s showing the WiFi7 icon there. Also same for the Apple Iphone as well.
Thank you.
Hoodcanalguy
Oct 08, 2025Aspirant
I have enclosed a screenshot for my iPhone. I’ll have to do the galaxy ultra later this morning as I factory reset that phone so I’ll have to set it back up.
- HoodcanalguyOct 08, 2025Aspirant
- FURRYe38Oct 08, 2025Guru - Experienced User
Which icon on the Galaxy shows being connected at WiFi7?
Please don't post pictures with phone serial numbers or IMEI information for security reasons.- HoodcanalguyOct 08, 2025Aspirant
On the left side halfway down, you will see the Wi-Fi symbol with a 7 next to it
