Groenvleugel
Jul 30, 2019Aspirant
RN314 Connection lost V6.10.1
RN314 Connection lost Hello, can anybody help me with the next problem. We have a readynas 314 which works fine. We can acces the drive and is fast. Somethimes the connection is lost, we ...
JohnCM_S
Aug 16, 2019NETGEAR Employee Retired
Hi Groenvleugel,
You can download the NAS system logs and then check the smbd.log. You may be able to find some clues there on why you are losing the connection on SMB.
You may also send to me the logs so we can check as well. You can do that by uploading it to a filesharing site then send to me the download link via PM (private message).
