Groenvleugel
Jul 30, 2019Aspirant
RN314 Connection lost V6.10.1
RN314 Connection lost Hello, can anybody help me with the next problem. We have a readynas 314 which works fine. We can acces the drive and is fast. Somethimes the connection is lost, we ...
Groenvleugel
Aug 27, 2019Aspirant
Hello JohnCM_S,
Thanks for your response.
We are using the NAS 314 for our business and eventually we have decided to buy a new NAS (424). It seems that something is wrong with the “user”rights and we also think that perhaps a reinstallation of the system could be a solution.
Because we need the NAS daily we now are using the 424 and probably will reinstall the 314 NAS which will be our backup system when it’s up and running again.
It isn’t fasted/cheapest solution but unfortunately we couldn’t rely on the 314 and that why we made this choice.
Thanks for your support.
Kind Regards,
Peter
JohnCM_S
Aug 28, 2019NETGEAR Employee Retired
Hi Groenvleugel,
You are welcome. :)
Feel free to post again in case you have questions, suggestions, recommendations or anything about your NAS that you think needs attention or will help others.
