Frank3523
Mar 28, 2020Aspirant
gs324t not manageable
Hello All,
Just bought myself a new switch GS324T.
But this switch is not manageable from my network.
If I connect straight with my latop I can give it an IP address, but when I move the switch to my network that is behind a ubiquity edge router I can't ping the switch anymore.
I already dit a firmware upgrade changed the ip but with no succes.
Any help would be appreciated.
can be closed, solved the problem it was spanning tree causing the problems.
Frank3523 wrote:Hello All,
1 Reply
- Frank3523Aspirant
