Help
222 TopicsIs 5Ghz band available in data offload mode on the nighthawk m6?
I consider buying a nighthawk M6, but before I do that, I need to know which frequency bands are available in data offloading mode. My current M1 only supports 2,4 Mhz when offloading data from another WiFi network, which is too slow for my KEF LSX speakers. I would at least need 5 Ghz. Does anyone know how this works in a M6 model? Thanks in advance! Kindly Jo124Views0likes0Commentssinds het gebruik van window11 op mijn laptops en vaste pc worden de poorten automatisch gedisabled
Als de pc of laptop in slaapmodus gaat wordt de desbetreffende poort gedisabled op de switch. Onder windows 10 nooit een probleem mee gehad. Onder windows 11 heb ik dit keer op keer. (Admin mode wordt automatisch op D-Disable gezet ipv Enable), waardoor de netwerkverbinding verbroken is. Hoe kan ik dit oplossen?172Views0likes0CommentsORBI RBE870 as access point question
Hello, I want to replace my RBR50 because one of my Satelites refuses to connect. It is now connected as AP and that works (worked) amazing, so I want to set up the RBE870 the same way and I have a question about that. In the instructions it says to connect your Orbi router to i-net router via ethernet. Next it says to connect your browwser on your laptop to one of 2 websites, but with wifi internet gone, how will that work? Or do you have to connect your laptop also via Ethernet to the either the i-net router or Orbi router? Any information (video links) are very much appreciated!172Views0likes0CommentsGUI switch GS716-100EUS management not accessible via the GUI (HTTPS)
I have a netgear switch mentioned in the subject. I recently got an email from NEtgear saying that there is a new firmware for my switch type that is available for download. See attached snap shot... The new firmware addresses a bug which I believe is also affecting my switch because I assigned a fix IP address via DHCP router. Switch is working fine however I cannot get access via the GUI (https). There exist a new firmware for this but I cannot implement this because of this bug. Beside the GUI, is there another way to connect to the switch and update the firmware? I would like to avoid full reset of the switch in order not to loose the complete configuration! Thanks in advance Maarc439Views0likes1CommentNetgear A6150 Wifi USB 2.0
Goede dag ik heb een HP Z-book met win.10. ik heb nu ook een intel-Nuc pc. Win11, die ik remote met wifi wil benaderen vanaf mijn laptop. ik heb een Netgear A6150 Wifi USB 2.0 adapter bij gekocht om deze verbinding te maken. (dan kan ik met de ingebouwde wifi adapter van de Z-book op het internet verbonden blijven). helaas vind ik met de Netgear adapter het wifi signaal van mijn intel-Nuc niet. en als ik met de ingebouwde wifi adapter van de Z-book kijk staat deze wel in de lijst. wat zie ik over het hoofd? moeten er adapter instellingen van de Netgear aanpassen ? Good day, I have an HP Z-book with win.10 and I now also have an Intel-Nuc PC. Win11, which I want to access remotely with WiFi from my laptop. I purchased a Netgear A6150 WiFi USB 2.0 adapter to make this connection. (then I can stay connected to the internet using the Z-book's built-in WiFi). Unfortunately, I cannot find the WiFi signal from my Intel Nuc with the Netgear adapter. and when I look with the built-in WiFi adapter of the Z-book, it is in the list. what am I overlooking? Do any adapter settings need to be adjusted on the Netgear?396Views0likes0CommentsNetgear Mobile app with Nighthawk M6 Pro
Bij het installeren van de Netgear Mobile app (Mobiel) op de Samsung S23 Ultra telefoon voor toegang tot de Netgear Nighthawk M6 Pro zijn alle meldingen geblokkeerd. Ik krijg de blokkade er niet vanaf. Wat is de oorzaak dat deze app van Netgear standaard alle meldingen blokkeert op de Samsung S23 ultra? Graag een passende oplossing voor bovenstaand probleem. Bij voorbaat hartelijk dank.437Views0likes0Comments
