MarBol's avatar
MarBol
GUI switch GS716-100EUS management not accessible via the GUI (HTTPS)
I have a netgear switch mentioned in the subject. I recently got an email from NEtgear saying that there is a new firmware for my switch type that is available for download. See attached snap shot...
The new firmware addresses a bug which I believe is also affecting my switch because I assigned a fix IP address via DHCP router.
Switch is working fine however I cannot get access via the GUI (https). There exist a new firmware for this but I cannot implement this because of this bug. Beside the GUI, is there another way to connect to the switch and update the firmware?
I would like to avoid full reset of the switch in order not to loose the complete configuration!
Thanks in advance
Maarc
1 Reply
