tonvanr's avatar
tonvanr
Tutor
Sep 08, 2019
orbi app no devices visible in device manager after upgrade firmware
after a firmwareupdate of my router and satellite to firmware V2.3.5.30 the connected devices are not visible; when i want to display the connected devices i get a error message "Sorry, the action was failed. Please try again.".
I get this error message over and over again. What am i doing wrong.
Thanks for your reaction.
  • Retired_Member's avatar
    Retired_Member
    I am having the same issue. Have you found a fix yet?
    • Edchen78's avatar
      Edchen78
      Having same issue. Can netgear please fix this issue! Been having issues ever since I bought Orbi.
  • I have done a firmware upgrade to V2.5.0.38 and it seems to be solved
    • Edchen78's avatar
      Edchen78
      Odd it’s saying I do not have new updates and I’m on v.2.3.5.30
      • tonvanr's avatar
        tonvanr
        Tutor
        as i recall the firmware update was through the web login
