Retired_Member
May 20, 2021account lock out for zero reason
i am getting account lock outs for zero reason how do i fully remove this useless feature?
TheDBug
May 24, 2021Tutor
I think I am getting the same issue as you after I upgraded to the latest software 6.10.5 yesterday. On some browser as soon as I type in the IP address to my NAS I get a prompt to reset password. On another browser (Internet Explorer) I managed to login to my admin page but as soon as it loads I get this Connecting to Readynas Admin Page.... and a prompt to re-enter my username and password and then I get the reset password page.
Sorry I do not have the solution, I have been searching and found your issue and I thought they might be related or the same issue.
- TheDBugMay 24, 2021Tutor
So far I have tried and OS reinstall and at least that let's me log in and do chagnes on my admin page
So with an OS reinstall resetting the admin password to: `password`, the admin page works. Once I changed the admin password to the one I usually use the problem has returned. So this is definitely and issue with the admin password.
- SandsharkMay 24, 2021Sensei
Some functions are locked out when the pasword is the default, so it could just be associated with the problematic function being locked out until you change the password. But that doesn't explain why everything works fine for most users but not all.
Are there any non-alphanumeric characters in the password you used?
- Apr 16, 2020Retired_Member
