doccy
May 11, 2018Aspirant
Basic question about how readdy cloud works on my NAS in my LAN
Sorry for the very basic question. I just can't seem to find the answer in my searches!
Just set up a new NAS212. used ready cloud to set up as recoommended and am now ready to migrate data f...
May 12, 2018Guru - Experienced User
ReadyCloud is designed to use the local network when that reaches the NAS, and to use the ReadyCloud VPN when it doesn't. That might occasionally not work as intended (at least I've seen some reports here to that effect). But generally it does.
You also don't need to use ReadyCloud when you are on your local LAN, so you can simply exit the app on the client device when you don't want to use it.
- doccyMay 13, 2018Aspirant
So... I don't THINK ready cloud stole all my bandwidth.
Not impressed though. After many hours of copying files it decided to log me out for some reason.
I went back in to restart the copy thinking it would do a nice incremental change and finish the copying I wanted... but no... it wanted to start copying all the files again with no option to miss out ones that had already been included.
Very annoying - I had to go back and use Raidar to do the task I needed.
- StephenBMay 14, 2018Guru - Experienced User
Why didn't you just use file explorer?
- doccyMay 14, 2018Aspirant
Well I did didn't I.... but intiially I tried ready cloud as i was encouraged to set up the NAS that way and it has the facility to transfer files in it.
But yeah - I won't do that again... using file explorer with RAIDAR makes more sense on your LAN.
