doccy
May 11, 2018Aspirant
Basic question about how readdy cloud works on my NAS in my LAN
Sorry for the very basic question. I just can't seem to find the answer in my searches!
Just set up a new NAS212. used ready cloud to set up as recoommended and am now ready to migrate data f...
doccy
May 13, 2018Aspirant
So... I don't THINK ready cloud stole all my bandwidth.
Not impressed though. After many hours of copying files it decided to log me out for some reason.
I went back in to restart the copy thinking it would do a nice incremental change and finish the copying I wanted... but no... it wanted to start copying all the files again with no option to miss out ones that had already been included.
Very annoying - I had to go back and use Raidar to do the task I needed.
May 14, 2018Guru - Experienced User
Why didn't you just use file explorer?
- doccyMay 14, 2018Aspirant
Well I did didn't I.... but intiially I tried ready cloud as i was encouraged to set up the NAS that way and it has the facility to transfer files in it.
But yeah - I won't do that again... using file explorer with RAIDAR makes more sense on your LAN.
- StephenBMay 14, 2018Guru - Experienced User
RAIDar is handy to have around - but you don't need RAIDar for this either, you can just use file explorer directly. Just enter \\nas-ip-address or \\nas-name in the address bar of file explorer (using the real ip address or name of course). That should give you a list of the shares.
