warriorseries
May 20, 2016Star
Can not login to admin page after firmware 6.5 update and Netgear account upgrade
Thanks to the "upgrade" I was forced to get a new account with netgear and now I can no longer access the admin page of my NAS, despite resetting the password several times. Anyone else having this ...
- May 20, 2016
The procedure to do an OS Re-install is described here: http://kb.netgear.com/app/answers/detail/a_id/20898/~/readynas-%26-readydata%3A-boot-menu
Leia
May 20, 2016NETGEAR Employee Retired
What account you used to login admin UI page? The "admin" or the ReadyCloud user(you entered in admin UI, Cloud page ReadyCloud panel)?
If you used "admin", and you cannot login with your password, you can reset the local admin password by doing an OS Re-install.
If you used ReadyCloud user to login admin page, since you already upgrade your old ReadyCloud user to MyNetgear account, you should use the MyNetgear account and password to login now.
mdgm-ntgr
- Apr 16, 2020Retired_Member
- Aug 04, 2022Retired_Member
- Jan 26, 2024Retired_Member
