warriorseries
May 20, 2016Star
Can not login to admin page after firmware 6.5 update and Netgear account upgrade
Thanks to the "upgrade" I was forced to get a new account with netgear and now I can no longer access the admin page of my NAS, despite resetting the password several times. Anyone else having this ...
- May 20, 2016
The procedure to do an OS Re-install is described here: http://kb.netgear.com/app/answers/detail/a_id/20898/~/readynas-%26-readydata%3A-boot-menu
warriorseries
May 27, 2016Star
I had to reinstall the OS on the NAS. All data was wiped and I had to start from scratch. most features are back up now, but still pretty ticked at NETGEAR for the forced upgrade when clearly they hadn't tested it very well
mdgm-ntgr
May 31, 2016NETGEAR Employee Retired
An OS Re-install doesn't touch the data. A factory default wipes all data, settings, everything. Sounds like you chose the wrong boot menu option. A factory default should only be attempted after exhausting all other options. You could have reached out to support before trying that.
- warriorseriesMay 31, 2016Star
I apologize, I didn't not proof read my post. The OS reinstall was successful in the sense that I was able to access the NAS admin page once again, however I did end up doing a factory reset in order to get ready cloud to work once again. And yes I did exaughst all other options. Still having serious issues with readycloud, but at least I can access admin to help try to solve those issues
- Apr 16, 2020Retired_Member
- Aug 04, 2022Retired_Member
- Jan 26, 2024Retired_Member
