warriorseries
May 19, 2016Star
Can not login to admin page after firmware 6.5 update and Netgear account upgrade
Thanks to the "upgrade" I was forced to get a new account with netgear and now I can no longer access the admin page of my NAS, despite resetting the password several times. Anyone else having this ...
- May 20, 2016
The procedure to do an OS Re-install is described here: http://kb.netgear.com/app/answers/detail/a_id/20898/~/readynas-%26-readydata%3A-boot-menu
mdgm-ntgr
May 30, 2016NETGEAR Employee Retired
warriorseries wrote:
I had to reinstall the OS on the NAS. All data was wiped and I had to start from scratch. most features are back up now, but still pretty ticked at NETGEAR for the forced upgrade when clearly they hadn't tested it very well
An OS Re-install doesn't touch the data. A factory default wipes all data, settings, everything. Sounds like you chose the wrong boot menu option. A factory default should only be attempted after exhausting all other options. You could have reached out to support before trying that.
warriorseries
May 31, 2016Star
I apologize, I didn't not proof read my post. The OS reinstall was successful in the sense that I was able to access the NAS admin page once again, however I did end up doing a factory reset in order to get ready cloud to work once again. And yes I did exaughst all other options. Still having serious issues with readycloud, but at least I can access admin to help try to solve those issues
- Apr 16, 2020Retired_Member
- Aug 04, 2022Retired_Member
- Jan 26, 2024Retired_Member
