icer91
Feb 09, 2017Aspirant
Cannot turn on ReadyCLOUD RN104
I have the same problem, where the ReadyCLOUD button switches back to 'off' everytime I click 'on'
Are there instructions on how to update the configuration file and the services config to make...
- Feb 18, 2017
icer91 your system was missing the serial number and MAC addresses for the ethernet ports. So I fixed that.
I also made sure you had the latest version of a config file.
icer91
Feb 18, 2017Aspirant
Thanks so much for your help! I'm not sure what you did, but it's working as it should now.
Thanks again!
mdgm-ntgr
Feb 18, 2017NETGEAR Employee Retired
