JoGo's avatar
JoGo
Change target folder or disc when using ready loud
How do I change disc Folder for ready loud target? It just creates a folder in one of the discs installed in my NAS. Br/Jorg
  • Marc_V's avatar
    Dec 03, 2019
    JoGo
    Welcome to the Community!
    What would you like to change? Is it the volume on your NAS? right now there's no way you can change the default volume the NAS will be using when creating a share for syncing a Windows PC or MAC OS folder to the NAS. It automatically creates a share on the first volume when a folder is synced through ReadyCloud app.
    You may want to post your Idea on the Ideas Exchange board for ReadyNAS. Getting enough Kudos can help engineers to add it as a feature/function.
    If this is not the case, kindly send a screenshot of what you are trying to do so we can better assist you.
    HTH
    Regards
ProSupport for Business
