tomiaurednik's avatar
Jun 22, 2016
copy dir/files from NAS to USB; NAS backup , cannot create directories
Hi,
RN104: 2 HDD Raid 1, v6.5
I would like to copy data (files, directories) from NAS to USB externa drive without using any computer. USB Flash drive connected directly to NAS.
How can I do it?
I tried with backup, but every time I get error NAS backup , cannot create directories. Also I 'm not able to create any bck to External USB?
Error backup job usb_copy : failure during copy.
Log:
Backup Job Name: usb_copy
Backup Job Type: Incremental
Protocol: local
Backup Source: [Public]/bck
Backup Destination: [USB_HDD_3]/
Backup Start Time: Wed Jun 22 2016 13:32:46
Backup Finish Time: Wed Jun 22 2016 13:32:47
Backup Status: Fail: failure during copy.
Cannot create directory “Name of directory”!
Any help will be appreciated.
  • StephenB's avatar
    Have you confirmed that you can write to the drive from a PC?
    What format is the flash drive?
    • BrianL2's avatar
      BrianL2
      NETGEAR Employee Retired
      Hi tomiaurednik,
      If you will change the destination via USB port destination (front/back), will that make a difference? Also, test with another USB storage device and see how it goes.
      Kind regards,
      BrianL
      NETGEAR Community Team
    • tomiaurednik's avatar
      tomiaurednik
      Tutor
      HI,
      I can w/r to USB from PC (connect USB directly to PC).
      It's NTFS file system
        tomiaurednik
        Tutor
        It seems that the problems ware, because it was not a safe remove from NAS. I Repaired on windows, now works.
ProSupport for Business
