sclubone
Jul 10, 2016Aspirant
Excess battery drain caused by RCloud iOS - Netgear should fix asap!!
After unexpected high battery drain on both my iPhone and iPad, it transpires that RCloud iOS will remain active in the background (for hours...) unless force-quit. The app shouldn't be in the iOS st...
sclubone
Aug 11, 2016Aspirant
No. What do you think it has to do with the app, when iOS reports battery drain by app in any case (with they netgear app identified)? Thanks
- BrianL2Aug 14, 2016NETGEAR Employee Retired
Hi JohnNulty & sclubone,
Thanks for responding back. Let me forward this information to my colleagues to further investigate this issue that you've raised.
Kind regards,
BrianL
NETGEAR Community Team
