Roger310's avatar
Roger310
export of snapshots
would like to automaticly export snapshots to my google drive account.
I have already setup the snapshot as weekly and made them visible.
I created the job using the google drive featue on the readynas local device and it appears to be communicating.
Not sure what I should be expecting as the individual snapshot folders are huge (64 GB which is the value of all the files I wanted snapshoted together.). I expected these files to be an image that was easily exportable. What am i missing? Google drive will only accept 15 GB.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Roger310,
    What is the storage capacity of your Google drive? Google Drive capacity starts with a 15GB free storage. They have a subscription plan for additional storage capacity. You may check this link for more information regarding that.
    • Roger310's avatar
      Roger310
      That's not the issue at this point. But yes I do only have the 15G with google at this point.
      I have 64G of information on the Nas drive.
      Why is the snapshot also 64G? It seems to me that it should be much smaller as its supposed to be an image file correct?
ProSupport for Business
