jcdick1
Aug 13, 2020Aspirant
Failed to retrieve Google Drive logs - where to find them?
I have a sync job for uploading from the ReadyNAS to a Google Drive account. When I go to check the logs for the job, it gives me an error:
Failed to retrieve Google Drive logs from NML
And has the message
Failed call Code: 38001010002
Can anyone point me toward where to find the logs for this on the system? I'd like to see what it last uploaded, and when the last time that was, as the Google Drive itself doesn't show anything being uploaded in the last couple of days. With no pauses, getting the full initial sync at 8.6M/s is going to take a month.
Of course, figuring out why it is failing the call would be good, too.
Thanks!
Where are you seeing this particular error message? Have you tried downloading the logs from the ReadyNAS admin web ui?
- jcdick1Aspirant
That is where I am seeing the message. When I click on the "history" icon in the Googe Drive settings, the window pops up with that message.
